Header clearance
Old May 19, 2007 | 11:13 PM
v8chvyguy's Avatar
Default Header clearance
Sorry about the double post, but, I notice that there's more exposure here. Here's the deal, I was under the car the other day, planning out the exhaust, and I realized that the reverse rod runs right where the header collector tube will. This is on a 79 Z 350 4 spd. and I got the 2451-1HKR header set from Hooker for the 327 I'm trying to get built. What I need to know is, Have any of you 4 spd guys had issues installing headers w/a BW T10? I'm thinking that this rod can be removed without affecting reverse operation, is this possible? My only other option is to find a set off stock manifolds w/a 2.5 inch outlet. I'm on the fence about installing the headers anyway, so, need some input in order to make the call. Thanks in advance.
BTW: 74454BB, Thanks for the ROTM support.
Old May 20, 2007 | 02:45 AM
thebandit110's Avatar
Default RE: Header clearance
what kind of 4 speed tranny???
Old May 20, 2007 | 08:19 AM
v8chvyguy's Avatar
A Borg Warner T10. The rod runs from the shift linkage, to a bell crank, up to the steering column. If it dose'nt block the header, it will certainly interfear with it.
Old May 20, 2007 | 09:12 AM
Rand's Avatar
YES!! My 70 Camaro had the same issue. The rod had to be removed. And it works ok......BUT then I have to turn the 'ring' on the steering column to turn the back up lights on and off.
Shift yours into reverse, with the rod on,and you should see a part of the steering column move, that is the back up light switch.
Hope this helps......
Old May 20, 2007 | 11:13 AM
v8chvyguy's Avatar
I thought it had someting to do with the back up lights. Seems abit elaborate for a backup light switch dose'nt it? Been working for 28 yrs though. Thanks.
kamaro68
Jun 29, 2011 07:38 AM
BLKOUT
Oct 19, 2010 04:14 PM
gray80
Sep 16, 2009 08:35 PM
Deagle85
Jun 12, 2007 07:11 PM
v8chvyguy
May 19, 2007 10:51 PM
