Gen light cuts on periodically.
Old Sep 7, 2012 | 02:17 AM
Jeromaro's Avatar
Default Gen light cuts on periodically.
In my '74 my gen light cuts on here & there. It's happen a few times this month. On two seperate occasions I had to wiggle the battery just a little for it to cut on. What could it be? Alternater perhaps?
All help will be appreciated.
Old Sep 7, 2012 | 02:58 AM
Sudstoy's Avatar
If it happens when you wiggle the battery i would assume just a loose connection. Check the power and ground wires, i would imagine it would be something simple. Put a volt meter on your battery when the car is running and see what it reads, that is usually how i tell if the alternator is charging, usually up over 14 volts when running.
Old Sep 7, 2012 | 10:28 AM
Jeromaro's Avatar
Thank you def gonna check it out.
Old Sep 10, 2012 | 11:09 PM
Sudstoy's Avatar
any news?
Old Sep 24, 2012 | 02:11 PM
Jeromaro's Avatar
The battery levels read fine. But still on the freeway it will stall at 50mph for about 45secs before reaching the speed limit as the light pops on. I'm assuming its the alternator so I'm getting around now to having it repaired. Thanks Sudstoy.
Anymore thoughts before I get a new alternator put in?
Old Sep 24, 2012 | 03:02 PM
Also make sure the alternator belt is not slipping, especially since the light comes on as speed increases.
Old Sep 27, 2012 | 01:03 PM
Rjtack's Avatar
---But still on the freeway it will stall at 50mph for about 45secs---
Are you saying the engine actually stalls, or the alt light just comes on?
biohazard
Jan 4, 2008 03:20 AM
wvblair
82-92 V8 Tech
Oct 11, 2007 01:40 AM
I_NEED_A_CAMARO
Oct 2, 2007 10:40 PM
mark102883
Apr 24, 2007 07:30 PM
