LT1/LT4 Tech 1993-1997
car cuts power
Old Jan 1, 2007 | 07:23 PM
mark102883's Avatar
Default car cuts power
my 95 Z28 will cut all power. sometimes it will start right up up again other times you have to wait. I will be going down the road and all power just cuts out. Battery, alternator and starter were all tested good. Anyone have any ideas.
Old Jan 2, 2007 | 12:52 AM
jtvyper456's Avatar
Default RE: car cuts power
Maybe a bad/shorted ground wire somewhere...check the big 3--
Battery ground to chassis
Battery ground to engine block
Battery positive to alternator (careful - often times it is routed thru the under hood fuse block)
That's my only guess if everything was tested working!
Old Jan 2, 2007 | 04:20 AM
My01Z28's Avatar
I had the same problem with an older car although it wasn't a camaro. It was a wire problem. My local mechanic had my car almost a month and never found anything. My advice is take it to Chevy, if you can't find it yourself.
Old Jan 3, 2007 | 03:03 AM
98ss4REAL's Avatar
Ihave a 95 z28 my cuz had before me an blew his engine (very funny story) so it was sent to jasper an replaced. Then after that i bought the car thinking new engine ready to go but not the case. I can be driving down the road an she will just die mostly when i am accelerating from a stop, but it happens on the highway, where ever it wants pretty much it has its own mind an when it dont wanna go anywhere it dies. I haave replaced everything u could think of an it has been to 3 different shops includeing a chevy dealer an no one can find out the problem. The only thing that wasnt replaced yet is the optispark so thats my idea an just about the only thing left to replace on it. i have had this problem for some time so i went out an bought another camaro 98ss and that was my fix. IF YOU SOLVE THIS PUZZLE LET ME NO A.S.A.P cuz i dont no wat to do.
Old Jan 15, 2007 | 04:54 AM
KoRN_Munky's Avatar
jake it might be ur ignition control module too. if that is screwed up that will tell the opti to do wierd things
Old Jan 18, 2007 | 12:19 AM
jshababy23's Avatar
I know this may sound way to simple, but make sure your intake isn't blocked? Good luck!
Old Apr 24, 2007 | 07:30 PM
mcnair's Avatar
I had the same problem with my 73 Camaro. Everytime I got to freeway speed 65-70 it would stall out. Pull over and wait 5-10 min. and go for another 5mi. Drove me nuts, new feul pump, kit the carb, change fuel lines. Guy told me to take the fuel line off before the pump and blow air thru it. That blew the clog out of the pick up sock in the tank and the car ran good for quite awhile. Now I know you can't do that with the fuel pump in the tank but there is a sock on the pick-up tube cause I've changed them. You may have to drop the tank and do that. Mite as well do the pump while your at it. Good Luck
logansz28
Sep 13, 2008 12:44 PM
Camaro4life90
82-92 V6 Tech
14
Mar 31, 2008 10:58 PM
biohazard
Jan 4, 2008 03:20 AM
wvblair
82-92 V8 Tech
Oct 11, 2007 01:40 AM
