Fuel Filter?
Old Dec 16, 2011 | 04:39 AM
BZpbp's Avatar
Default Fuel Filter?
Working my way through fuel system on the 80 Z.....have replaced fuel filter in the quadrajet inlet...is there another inline filter in the system?
Old Dec 16, 2011 | 12:12 PM
Not that I know of, but who knows what someone may have added. I'd check the routing of the fuel line to visually inpect for another filter.
BTW, that sintered bronze filter in the inlet is a POS. They plug up easily, and most people remove them and install an easily serviced inline somewhere close to the engine.
Old Dec 16, 2011 | 12:40 PM
Your Q-Jet should have a longer fuel inlet horn, which uses a paper filament filter, and is a bit longer than the bronze filters that were used in the older flush mount inlet model. That should be sufficient, unless you're ramping up your fuel requirements. If needed, you can use a better in-line filter, but then throw the in-carb filter in the trash.
jon_uscg2001
Aug 25, 2011 12:23 AM
TrammelZ28
Sep 17, 2007 06:44 PM
johnson3034
May 25, 2007 09:35 PM
jtvyper456
Dec 31, 2006 09:33 PM
94camaroLI
May 16, 2006 09:57 PM
