frame repair opinions
Old Jan 23, 2008 | 07:48 PM
74LTcamaro73LT's Avatar
Default frame repair opinions
my 72 frame after I separated it from the body, on one side the frame appears to have rusted or been drilled, I was going to replace that spot, with some new steel, would that be advisable,
or any other suggestions???
compare the drivers side with the passengers, the drivers is much bigger, what do you suggest
[IMG]local://upfiles/11243/54F2F343102A40068E6CFA7DD87E4BD0.jpg[/IMG]
[IMG]local://upfiles/11243/63BE4BC912404B4D827AE7DA4646F467.jpg[/IMG]
[IMG]local://upfiles/11243/2EED2E8598FF4ADA86ADEA22EBD0143B.jpg[/IMG]
Old Jan 23, 2008 | 08:13 PM
GRIFF's Avatar
Default RE: frame repair opinions
If the rest of the metal looked ok I would weld a plate on the underside and then weld a filler piece in the top to make it the same level and cut out a new hole. you could do it a number of ways I guess doesnt look like too big of a deal. The biggest problem I had with mine was the rear frame rail area and where the front of the leaf spring bolts on.
Old Jan 23, 2008 | 10:42 PM
1969 SS's Avatar
ORIGINAL: GRIFF
that is a very common fix
Old Jan 24, 2008 | 07:57 PM
kyphur's Avatar
Camaro performers magazine had an article exactly on what you're asking. It was the September 2007 issue, page 43 and 44 where they use a heavy duty industrial steel washer. They mark the area with the washer as a template then use a greenlee hydraulic hole punch to knock out the hole exactly to make sure they're getting rid of all the deteriorated metal. Next they use a small grinder to clean it up for an even fit. After that they just clamp it in place, do a thorough weld and grind it down. In fact I'm about 90% sure that it's the exact same spot they do it on theirs that you have in the pic.
Old Jan 27, 2008 | 08:29 PM
i think i will try both options thanks for the input, just curious does anyone happen to know approx. what the diameter of the hole should be? seems to be about 1 1/2 -2" is that gonna be too much for the body mounts?
Old Jan 27, 2008 | 10:12 PM
1969 SS's Avatar
off the top of my head, I don't know the size but why don't you just measure your mounts and cut it a little oversized. I do know they are a standard size. some resto-houses might even sell the replacement plates so they would know the opening size
destroyer432
Feb 11, 2013 10:34 AM
mccoyj91
Jul 4, 2010 10:44 PM
Sanman
Jan 23, 2010 02:11 PM
Camaro_Boi69
May 22, 2008 02:38 PM
74454bb
Aug 29, 2006 10:46 PM
