First Thread
Old Jun 11, 2012 | 08:29 AM
  #41
WatsonCustoms's Avatar
Lol okay, sorry for the confusion. i wired everything up, speakers, radio, and subs. Everything worked PERFECT. Then, the next mornin nothing worked. I checked some fuses but nothing. as far as the battery, it was still connected at the time. As for today, its disconnected. I guess ill check my fuses once more. Whats the chance I couldve fried my radio? Its a $200+ pioneer, so I surely hope not..
Old Jun 12, 2012 | 12:25 PM
  #42
MKCoconuts's Avatar
Check the fuse in the back of the radio and make sure it's getting power from the harness.
Old Jun 15, 2012 | 08:09 AM
  #43
1995Z/28's Avatar
also, make sure you dont have any "fusable links" anywhere that could have went south...i had this issue before in one of my G-bodies. i had no juice and for the life of me couldnt figure out what was goin on. finally found a fusable link that got popped and it apparently was added by a previous owner that was trying to fix a cut wire and instead of using the correct wire, he spliced in the link ( it looked like he didnt know it was a fusable link, rather, just a piece of wire) and it popped. your radio should have a blade fuse right in the back if its a newer unit, or an inline fuse holder on the hot wire. you can always check your HU by just hooking 1 speaker to it (out of the car) and powering it up on the battery ( FUSE IT!) if it turns on and works, you know you have to look elsewhere. where did you pull you constant +12v from? cig lighter? or straight from the battery? or fuse block? also, make sure you didnt cross your constant +12v with your keyed +12v wires. its easy to do.
Kkubal3
May 17, 2015 08:40 AM
draekus
May 29, 2010 07:50 PM
35thCamaro
Mar 7, 2008 11:44 PM
