engine good or bad
Old Nov 15, 2009 | 02:52 PM
daleas88's Avatar
Default engine good or bad
code 10066036 2 or 4...Target Master/Goodwrench crate motor, 2-piece rear seal...."hecho en mexico" anyone know about this motor or no? is it worth rebuilding it? i would like to bore it out throw a nice cam in and some nice dished pistons and push about 400 hp or so.... is it worth it?
Old Nov 15, 2009 | 03:48 PM
should be. its a 350 small block. not sure what the 2/4 means. either it came in both 2 and 4 bolt mains and u have to look to see, or, it has 2 bolt mains on the ends and 4 bolt on the other journals. depending on what u want to do it may be a good idea to look to see what it is. if u want to do some juice or forced air it would be a good idea to have 4 bolt.
Old Nov 15, 2009 | 09:34 PM
JRs72RS's Avatar
February 2009 ROTM
At a target of 400 hp you don't need to worry about 2 or 4 bolt mains. Decent crank, rods and pistons (well balanced of course) will hold up just fine on 2 bolt mains to over 500hp. The target 350 engines had good castings and are good rebuildable blocks. Get the machining done first and use good quality parts, it will be fine.
Old Nov 17, 2009 | 01:10 AM
Adam78's Avatar
i have the same engine in my 78, she sat untouched for 8 years and cranked right up, puts out alot of power even though it really needs a rebuild. all in all i think its worth rebuilding.
Old Nov 17, 2009 | 10:12 AM
daleas88's Avatar
thanks for all the help guys
emperorclobbersaurus
Jun 16, 2012 09:03 PM
jakunert
Mar 29, 2012 06:41 AM
1980rscamaro619
Jun 24, 2010 04:12 PM
dnulnarts
Jun 25, 2007 05:08 PM
