Electrical Stuffs (Stereo & Some Loose Wires)
Old Aug 10, 2012 | 06:22 PM
  #21
The inner shaft moves with a rod from the transmission linkage to the column. Look under the hood and have someone move your trans shifter back and forth. The rod should move at the firewall when the shifter is moved.
You can also climb under the car and follow the rod from the trans to the firewall and see if it fell off either end.
Check this diagram post #2 by Hoot:
http://www.nastyz28.com/forum/showth...ng+rod+shifter
Old Aug 13, 2012 | 07:29 AM
  #22
voxeltoxin's Avatar
thanks for the info.
after looking at your link then checking out my car i became very depressed. lol. apparently i am missing all of the linkage between the trans and the column.
so does anyone have any links where i can buy all of it for cheap ?
Old Aug 13, 2012 | 10:48 AM
  #23
Try FbodyWarehouse :: 1978 - 1981 Camaro
They may have used pieces for sale. Tamaraz probably sells it all new. Is there a junk yard near you?
Old Aug 13, 2012 | 11:20 AM
  #24
You could also convert to a cable operator if you have some fab skills.
01camaro.dude09
Aug 29, 2011 11:54 AM
black95z28
Mar 9, 2010 11:05 PM
mrEmolitov
Jan 12, 2009 11:32 AM
sl1foru
Nov 2, 2008 07:49 PM
ScottD
Oct 28, 2008 11:02 PM
