Electric fuel pump mounting location?
Old Jul 31, 2012 | 07:46 PM
exlimey's Avatar
Thanks for the heads up Damon. I'll definitely take your advice. I'll have to check the Summit and Jegs catalog for a mounting plate. I may be able to fabricate one too. I was hoping to use one of the ports on the regulator for a pressure gauge but I'm sure I can figure something out if I use a mounting plate like the one in your post.
Val, I noticed on the gasser that the pump appears to be mounted upside down. Will it work in either orientation?
Old Aug 1, 2012 | 09:27 AM
Originally Posted by exlimey
Vall, I noticed on the gasser that the pump appears to be mounted upside down. Will it work in either orientation?
I'd call that position right side up. They will work in any position on every pump I've ever purchased.
Old Aug 2, 2012 | 04:20 AM
exlimey's Avatar
Good to know. I assumed the normal orientation is with the "Holley" logo readable but it gives me more options if it will work either way. Now that I think about it, I can see that it shouldn't make a difference which way it is. Thanks again!
Old Aug 2, 2012 | 01:50 PM
No logo on mine, but the bracket would be on the bottom if I had it the opposite way, which would mke a pretty long bracket needed to mount it.
Old Aug 3, 2012 | 09:04 AM
exlimey's Avatar
This is what I have. I think if I mount it with the Holley logo readable then I can get the pump lower and tucked inside the frame rails easier. When I get it fabricated I'll post a picture. To rubber mount the pump, is there a good source for the rubber isolators or do you just use a piece of rubber stock?
Old Aug 3, 2012 | 10:12 PM
Ummm.. If you slide the pump out of the bracket and flip it over, the logo will still be right side up. No up or down on these, just in and out.
Error_505
Mar 18, 2012 09:17 PM
er1c
Jun 3, 2009 01:20 PM
Celticsfan
Oct 29, 2006 10:36 PM
68greenss
Jul 12, 2006 10:14 AM
sewerrat
Jun 24, 2006 05:51 AM
