cost? weatherstripping
Originally the windshield and Rear window used a self sealing bead (3/8" dia.) in a role form and it cost about $9.95 a role. Most glass company's will use a rubber caulk adhesive that seals much better but not original. Make sure they set the glass to the proper depth or else the chrome will not fit correctly.
Weather-strip kit (door, roof rail, truck, quarter, u-jamb, window felt, window run channel) is a ww-37 @ Ricks First Gen for $209.00
Window felt kit is ww-40 for $229.00
67 Vent window weather-strip ws-6 for $57.95
Good Luck!
Good Luck!
Trunk weatherstripping should cost around 20 bucks with shipping. I have seen window weatherstripping go for 70 a set. not to bad if you ask me. Good luck. A couple hundred bucks is better than a rusted out trunk.
1967, 67, camaro, charge, cost, coupe, doorwindow, forum, replace, replacing, stripping, weather, weatherstripping, windshield
