carb spacer
Old Dec 26, 2007 | 12:28 PM
daltons 1980's Avatar
Default carb spacer
hey i just order a carb spacer for my car.....does any1 kno what this really helps?...i kno it gives the fuel and air more time to mix so will this give me beter fuel milege or just run better?...ill find out tomarrow cuz im puttin it on right after i pick it up lol...but i was j/w if it like helps more in the bottom end or topend or just all around....i kno it probably wouldnt be a huge noticable diffrence but its somethin i can afford to tinker with lol
Old Dec 26, 2007 | 01:35 PM
Default RE: carb spacer
The best answer is...it depends. What type of spacer did you get? The 4 hole style is designed to give better low-end response. The open style is designed to give more high rpm power (think of it as a paired down version of those cool tunnel-rams you see). Then there are combination spacers that work throughout the entire rpm range. If nothing else, it is putting the carb a little further away from intake manifold heat. Just be sure to check your hood clearance before you slam the hood and dimple it.
Old Dec 26, 2007 | 02:43 PM
its the one with the 4 holes in it..witch if thats low end it makes me happy cuz my car seems to need some help it the low end...and im pretty sure it will fit under the hood....cuz i bougth a 1inch spacer and i have maby an inch and a quarter clearence in the scoop above the carb...also for the heat thing....he guy said that he ordered a newer style one made out of an almost plastic material thats suppose to disperse heat better..idk well see how it goes tomarrow
Old Dec 26, 2007 | 09:03 PM
There are two kinds of plastic/almost plastic spacers. One is a true el-cheapo plastic, and the better one is a phenoloic material, which is basically a glass/resin that is molded under heat and pressure. And, it's not that it disperses the heat, but it doesn't allow heat to transfer through as much as aluminum will. Since you're referring to a "newer style" that's probably the one you're getting.
Old Dec 27, 2007 | 04:22 PM
yea it was that phenolic stuff...but i put it on today..and it seems to have made it more of a dog then helped it......like it still has the power cuz itll get up and go but it feels like tis taking longer...but did it like just change the power curve that much or what cuz its really buggin me
blackZ281983
Jun 4, 2010 08:15 AM
mikes77camaro
70-81 V8 Tech
Aug 28, 2008 02:49 PM
GoofieJ21
May 4, 2008 07:14 PM
thebandit110
Feb 13, 2008 02:23 PM
350rs
Sep 18, 2006 06:05 PM
