79 camaro floor pan problem
Old Dec 16, 2007 | 09:37 AM
johnson73801's Avatar
Default 79 camaro floor pan problem
hi everybody. i was needing to know if anyone knows if anyone makes a floor pan for under the rear seats of a 79 camaro i was going to pro street mine so i cut the foor for my fourlink kit and now i have changed my mind and want to go tourin with it. any help is appreciated.
joey
Old Dec 16, 2007 | 10:47 AM
v8chvyguy's Avatar
Default RE: 79 camaro floor pan problem
I am sorry to say that no one makes the rear seatpan for second gens. I'm looking for the same sheet metal for my friends 79 Berl. I have done every serch I could think of and had no luck. I even looked up firebird parts with the same results.
Old Dec 16, 2007 | 08:53 PM
I can not picture what you looking for but Classic Industries list a Full length floor pans. They have it listed in halfs or quarters. By the picture it looks like its from firewall to rear hump.
Page 525 in their manual or C6572 for the set.
Old Dec 17, 2007 | 06:40 PM
kyphur's Avatar
yeah, i wanted to say that NPDLink.com had them too.
Yeah, in their "body parts and sheet metal" section they have both the rear pans alone for 37.95 (right or left) for 75 - 81 models. Full lenght ones for the same years are 77.95 for right or left. I want to say I've even seen someone producing the entire floor now from firewall to trunk divider.
Old Dec 18, 2007 | 06:35 PM
allof the floor pans availible stop just b4 the rear seat. im needing under the seat and the trunk devider
Old Dec 18, 2007 | 07:10 PM
kyphur's Avatar
full floorpan but it's for a 70 - 73. You might be able to contact them and ask if their supplier has a 74 and up even though I'm pretty sure the 74 shares the same floorpan as the 70 - 73's since 75's when the catylitic converter started showing on them if I remember correctly. And if not you might be able to modify this for your needs.
I'd probably even try calling NPDlink.com directly. I've called them to order a part and getting another part that wasn't even in their catalog while I was at it.
Old Dec 25, 2007 | 10:45 AM
v8chvyguy's Avatar
I have contacted the supliers and was told that what's in th ecatalogue is it. My guess is that you are looking for the portion that the seatbelt and the lower rear seat are fastened to. They all rust out above the front leafspring perch and the inner wheel house
Old Dec 25, 2007 | 10:59 AM
v8chvyguy's Avatar
This is the Berl I mentioned.
Old Dec 27, 2007 | 07:26 PM
kyphur's Avatar
This is one of the other sites I forgot to mention that's pretty good too. This is the site I was actually talking about where I called and found a part not in their catalog. Not sure if that's it but it looks like it's the area in your pic with the brace for the bolt. not too sure though.
Here's their body section.
Tommo98765
May 30, 2013 04:03 AM
hurley870
Sep 24, 2012 04:04 PM
cdnturboz
May 23, 2011 11:02 PM
libertyforall1776
May 28, 2010 02:47 PM
thomas123
Jan 31, 2010 06:26 AM
