fan spacer
Old Feb 8, 2008 | 09:11 PM
thebandit110's Avatar
Default fan spacer
i have to put a smaller fan spacer on for my new electric fan. but i cannot ge the old one off. any ideas how i can??? thanks
Old Feb 8, 2008 | 10:43 PM
1969 SS's Avatar
Default RE: fan spacer
what do you mean spacer? pics?
Old Feb 8, 2008 | 10:54 PM
i have a spacer for the mechanical fan. but im putting a new electrical fan on so i have to move the mechanical one back. sorry i didnt clairafy. my bad. ill get pics up tomorrow.
Old Feb 9, 2008 | 12:46 PM
1969 SS's Avatar
so you're putting an electric fan on the same side as the regular fan AND you're keeping the regular fan? why, why, why?????
Old Feb 10, 2008 | 11:52 PM
619Camaro's Avatar
February 2008 ROTM
I was wondering the same thing. If you put an electric fan then you shouldnt need the mechanical fan imo. As long as the new one is pushing enough cfm. If your car can't cool with just one of those then there is a problem.
Old Feb 11, 2008 | 11:35 PM
got3ofem's Avatar
I have both too. The mechanical fan works fine for street driving, and the asthetic value, while I use my dual thinflexalite elect. fans for when im sitting in traffic, which I turn on when the temp hits 200. They work great together, esp. on hot summer days...
Old Feb 12, 2008 | 10:18 AM
1969 SS's Avatar
the only way you should use two fans, is if you run your electric fan in front of the radiator
Old Feb 12, 2008 | 11:45 PM
got3ofem's Avatar
Could you elaborate on that? Wouldnt a pusher fan have to work harder, based on its design, restricting more airflow from the fans motor housing--thereby using more electricity, and running longer to cool at the same rate,than a puller fan, which doesnt restrict the natural flow of air through the front of the radiator? Or, is there another reason?
Old Feb 13, 2008 | 12:05 AM
619Camaro's Avatar
February 2008 ROTM
ORIGINAL: got3ofem
I see,out here in San Diego it doesn’t get very hot, but I also don't drive during peak commute hours.
Old Feb 13, 2008 | 10:29 AM
1969 SS's Avatar
ORIGINAL: got3ofem
huh?
basically if he is running a fan off of the water pump, he will use that as his primary fan, and then if his car gets too hot from sitting in traffic, he can supplement that by turning on the electric fan, acting as a pusher,in front of the radiator
