Camaro 396 SS 1970 - threw white smoke when tried to start
Old Apr 11, 2021 | 06:55 PM
JohnnyZee78's Avatar
Default Camaro 396 SS 1970 - threw white smoke when tried to start
Hi all. Got a 1970 SS 396, 450bhp. Low mileage on fully rebuilt engine.
I tried starting it and it seemed the battery was almost dead. The engine wouldn’t crack. I kept turning the ignition and pumped hard on the fuel a coupe of times. It seemed the engine cranked a bit and o saw white faint smoke coming out of the valve covers / under the air filter. The car didn’t start anyway. I turned it off.
Really worried if it is the gasket or something serious.
hope it was only rich fuel (from the extra pumping).
please advise.
Old Apr 11, 2021 | 09:41 PM
Sounds like you flooded it. Holley carb? Double pumper?
Old Apr 12, 2021 | 05:35 AM
Default Thanks ... yes it is a Holley perf carb.
I think the coolant is clean and so is the oil dipstick. So hopefully the gasket is not fried :-).
Hopefully I had just flooded it with fuel.
Old Apr 12, 2021 | 05:36 AM
Everett#2390's Avatar
As suggested by Y2K, probably flooded it and along with this, a low battery charge not being able to crank engine over fast enough for creating a vacuum for drawing in fuel/air to start.
When parked for long periods, a battery tender/charger should be connected and turned ON , or you'll lose a battery later.
Old Apr 16, 2021 | 10:06 PM
Thanks for all the support and suggestions guys. Highly appreciated.
It was the battery I guess. Replaced it and it worked fine for two days.
Now ended up having starter issues I guess (have opened a separate post on it and receiving great help from all you guys at the forum - thanks).
Brad74 camaro
Sep 6, 2018 10:20 PM
Cody0103
Jun 27, 2010 01:03 PM
kidd429
Sep 6, 2008 09:19 PM
frostlime69
Nov 29, 2007 09:08 PM
T10wheels
82-92 V8 Tech
14
Nov 4, 2006 02:57 AM
