1974 camaro white smoke
Old Sep 3, 2018 | 07:51 PM
Brad74 camaro's Avatar
Default 1974 camaro white smoke
hey guys bought a 74 camaro and have some white smoke coming out of the tail pipes.
any thoughts? is the engine shot?
thanks!!
below is a link to my youtube to see the smoke
https://youtu.be/XOHPFHbeqMY
Old Sep 3, 2018 | 08:25 PM
Need more info.
Does it do this only after a start up, but goes away after a drive once the engine and exhaust warms up? Could be moisture in the exhaust.
Does it get worse the more you drive the car? That's more of a sign of engine problems.
Does the weather make a difference; hot & humid, cold & damp etc.?
Is your coolant level constantly going down, or no?
Old Sep 3, 2018 | 08:29 PM
it doesn't do it when i first start it up. It takes a few minutes and than starts smoking. I also have some smoke in the engine around the valve cover gaskets and down by one of the plugs.
it stays smoking and doesn't go away but doesn't get worse.
Old Sep 4, 2018 | 01:53 PM
flat tire's Avatar
white smoke "usually" means water in the combustion chamber
blue "usually" means burning oil
black "usually" means running to rich OR THE CAR IS ON FIRE
Old Sep 4, 2018 | 09:31 PM
Zspoiler's Avatar
Bad head gasket s and or warped head,
Old Sep 5, 2018 | 07:55 PM
Y2K's Avatar
Y2K
Sounds like a head gasket alright. Check your oil, if there's a lot of grey foamy stuff you are probably getting coolant in the oil as well.
Also look for oil in the radiator, could be either or both depending on where the gasket blew out.
This can kill an engine pretty quick if you keep driving it when it might just be a simple fix by doing a head gasket.
If you determine it is a head gasket you'll want to put a straight edge on the head when you get it off to be sure it's not warped.
Old Sep 6, 2018 | 12:28 AM
Al Loyrat's Avatar
Is it using coolant? When you check the radiator (engine cold start running) look for oil floating and look for bubbles. If water gets in the oil, it looks like a chocolate milk shake.
Pull all the spark plugs and check for a discolored plug(s). If it's #1 or #2 that looks bad, that could be a cracked or loose intake manifold or gasket. While the plugs are out, do a full compression test.
Old Sep 6, 2018 | 10:20 PM
Default thanks
thanks guys, i will check your recommendations this weekend. hopefully its not too expensive to fix!
jimm417
82-92 V8 Tech
10
Jun 4, 2012 10:42 AM
BOOGYMAN1313
Jun 6, 2011 09:53 AM
allamericanz28
LS Series Tech
May 13, 2009 12:50 PM
kidd429
Sep 6, 2008 09:19 PM
T10wheels
82-92 V8 Tech
14
Nov 4, 2006 02:57 AM
