little bit of smoke?
Old Nov 9, 2007 | 01:57 PM
frostlime69's Avatar
Default little bit of smoke?
I've noticed on rare occasions when I'm on the highway at normal speed 65 and then to make a pass I'll step on it to aquick 75-80 and back off the gas to 65 or so, at the point of deceleration theres a small amount of smoke from the exaust 1-2 seconds or so. Never smokes at any other time, (start up etc). Could it be excess fuel from quick acceleration to deceleration? Kinda unnerving. Thanks
Old Nov 9, 2007 | 03:07 PM
SickSickSick's Avatar
Default RE: little bit of smoke?
the general rule is black smoke - fuel .... gray smoke - oil ... white smoke - moisture vapor ... Sick
Old Nov 9, 2007 | 03:17 PM
It is dark, so it probably is fuel, since no smoke at any other time. I didbuy a rebuilt carb, but have not really put it to thetest yet.
Old Nov 9, 2007 | 05:54 PM
wildpaws's Avatar
If you don't really "get on it" often, it can also be residue (carbon, etc.) built up in the exhaust system. Or too rich a fuel mixture can give you that. I liked the exhaust pipes on my '69 Z/28 to look grey/white as a sign that it was tuned/running properly (never black looking pipes), but that may be too lean a mixture for todays fuel.
Clyde
Old Nov 29, 2007 | 09:08 PM
1stgenssclone's Avatar
could be trany fluid from the modulator depending on vacum line routing
check the trany fluid , are the plugs clean, i mean if the modulator is bad it will pull trany dluid into the vacum line and burn it through the engine, sometimes fouling a plug ......posibly
Mesosneaky
Jun 9, 2009 03:03 PM
xeet2050
82-92 V8 Tech
Sep 3, 2008 08:39 PM
3.4CamaroCDOG
Mar 16, 2008 03:13 PM
94Z28interceptor
Nov 29, 2006 01:29 AM
