A/C System Problems >>>>
Old Jun 14, 2012 | 09:57 PM
TruSiaki's Avatar
Default A/C System Problems >>>>
Can someone tell me what I need to do? I Really Want Cold AC.
Car: 1979 Chevrolet Camaro
AC/Heater Fuse: Brand New and Correct Fuse
Accumulator: R12 Vacuumed out, Retrofitted for R134A
Hoses: Hooked Up Properly
Compressor: Will Not Engage. Out Of Oil Maybe??? Will Adding Oil To It Make It Work?
The Compressor will spin when i hook the plug up to a tester. But it does not engage when it is plugged up, the ac is turned on to the max.
What Do I Need To Do To Fix My AC Problems??
Old Jun 15, 2012 | 03:51 AM
B.M.'s Avatar
Did you add the oil charge when the retrofit was done?If not then that may be the problem,i dont know much about a/c units,but i know there is an oil charge that gets added when you add the refridgerant.
c00nass
Oct 26, 2013 04:36 AM
kjvforme
Jan 2, 2012 09:39 AM
v64thgen
Jan 1, 2012 03:22 PM
randyf
Oct 15, 2011 08:54 AM
69camaro1
Oct 11, 2006 03:59 PM
