a/c heater blower motor question.
Old Oct 25, 2008 | 10:46 PM
kerbykk's Avatar
Default a/c heater blower motor question.
my blower motor works on all settings but not max.i replaced blower motor even though i doubted it was bad because if it works at lower speeds i seen no reason it would not work on high.still wont work on max,so i replaced the switch and still no max on the blower motor.when i installed the blower motor i seen where it connects to a small metal box near the firewall.is this where the resistor would be???or any other ideas why the max wont work???and yes i did try it on a/c and heat settings on the controls.thanks
Old Oct 25, 2008 | 11:33 PM
JRs72RS's Avatar
February 2009 ROTM
Default RE: a/c heater blower motor question.
Depending on the year of your car, there is probably a high speed relay. In air conditioned cars it is located on the side of the A/C housing under the hood. I think some years also had a high speed fuse under the hood. A small in-line fuse holder above and slightly left of the distributor.
Old Oct 26, 2008 | 12:20 PM
73camaroSS's Avatar
thats weird cause on my 73 the max only works lol.
Old Oct 26, 2008 | 03:47 PM
JRs72RS's Avatar
February 2009 ROTM
If you only have max, the problem is with the connections or the resistor itself.The resistor is mounted into the heater/AC housing and has three or four wires going to it.
Craig Ferguson
Apr 6, 2014 07:19 PM
wiskow
Jul 26, 2012 10:55 AM
edog2
Mar 30, 2010 09:02 AM
OldBruns
67-69 V8 Tech
May 1, 2008 12:57 AM
Booder
Oct 29, 2005 10:24 PM
