Brakes question
Old Nov 27, 2006 | 03:40 AM
Caddylack's Avatar
Default Brakes question
Alright, on Thanksgiving I picked up a 1980 Z28. So far, I've been afraid to really get on it because the brakes are worthless. If I had to stop, it would just not happen. The pedal doesn't go to the floor, it's plenty firm. There is no screeching or anything when stopping. Everything feels normal, it just takes the car forever to stop. What might the problem be?
Also... the car has a header leak. Should I buy new headers, or is there an easier way to fix the problem?
Thanks,
Matt
Old Nov 27, 2006 | 11:47 AM
shnormo's Avatar
Default RE: Brakes question
is the header rusted out or is the gasket just broken?
shnormo's Avatar
It could be a bad brake booster also?
Old Nov 27, 2006 | 09:20 PM
69camaro1's Avatar
If it were the brake booster it would just make the brake pedel harder to push than even manual brakes because you have to push through the booster. It does not determine how well the brakes stop as long as you put some muscle into it. I think it is greasy or oily drum linings that could be because of leaky axle seal lining(s).
camarodude77
Dec 16, 2015 05:52 PM
Dana
Oct 18, 2013 03:14 PM
imalixZ28
Jan 20, 2010 12:26 PM
osduck5
Jun 12, 2009 08:47 PM
agirlscamaro
Jun 7, 2008 05:12 AM
