which big block ????
Old Dec 18, 2009 | 08:36 PM
thechink09's Avatar
Talking which big block ????
i have a 1980 z28. currently i have a 350 with a built th400 behind it.
My step dad has a 1968 bbc 396 and a 1960 something or early 70 bbc 427 in the garage but they both need to be rebuilt.
Its not something im going to do anytime soon but i would like to rebuild one of them and put it in my car.
which one do you think would be the best?
or should i just get an already rebuilt 454?
Old Dec 18, 2009 | 09:00 PM
nothing wrong with either one. i would use the 427. more power.
Old Dec 18, 2009 | 09:10 PM
thechink09's Avatar
thats what i was thinking about. but would it be worth rebuilding the 427? or would it be better to just get an already built 454?
Old Dec 18, 2009 | 09:17 PM
Y2K's Avatar
Y2K
Well it depends on what's what,you may want to use parts from both depending on what's there.
396/427 is the same engine except the 427 has a bigger bore.
Some were 2 bolt main some 4 bolt,some had cast cranks some had forged steel,some had hi performance heads and some even had aluminum hi performance heads so we need to know what is what.
If one is a 4 bolt block I 'd use that block.
If there is a steel crank in one I'd use it,same crank fits both 396 and 427.
The heads interchange too so if you have the rectangular port open chamber heads on one use them on whatever block you choose.
If both motors are the same save cid then use the bigger 427.
Old Dec 18, 2009 | 10:56 PM
thechink09's Avatar
thanks that was really helpful. ill have to take a look at them when i get a chance
Old Dec 19, 2009 | 11:16 AM
I agree 100% with Y2K! I'd always go with the 427 if everything else is equal.
decaen
Feb 16, 2012 01:08 AM
tecumseh
Mar 8, 2011 01:01 PM
gadmhahn
Oct 9, 2009 09:20 PM
acarius
Apr 7, 2009 05:53 PM
Carinhas
67-69 V8 Tech
13
Aug 23, 2007 05:02 PM
