best spark plugs for a 1974
Old Jul 24, 2021 | 07:49 AM
74zcreation's Avatar
Default best spark plugs for a 1974
i am a new owner of a 1974 Camaro with a Jasper 300hp 350 with long tube headers. Which spark plugs are the best? i saw a review video that stated that the Accel shortys were not good, only last 2000 miles. He recommended a Autolite.
Old Jul 24, 2021 | 08:52 PM
Autolite is fine so is AC Delco,don't really need anything special for a 300/350.
Old Jul 25, 2021 | 05:18 AM
Everett#2390's Avatar
Autolite
Old Jul 25, 2021 | 05:00 PM
Heat range and gap are more important then maker unless this thing has some type of specials ignition or fuel injection system. I have always been a fan of AC delcos. Getting the proper heat range and gap ends up being trial and error unless you have the motor dyno tuned. To get that right you really need to know how to read plug. Just a basic set of boxed AC delcos are can work for 80,000 miles is a standard HEI type ignition. (Under 40,000 volts). If you ignition system is over 40K find out the manufactures recommendation for plug, They will need your compression ratio.
Old Jul 26, 2021 | 05:02 AM
thanks, i will go with the AC Delcos. My engine is 300hp. mild cam, 9:! compression. standard points ignition and 4brl carb.
jimbiker
82-92 V8 Tech
Dec 17, 2012 04:59 AM
aaron_Z28
Oct 19, 2009 03:32 PM
JaySan
Aug 13, 2007 11:39 PM
jds88z28
Aug 1, 2007 10:20 AM
davidalvarez82@hotma
LS Series Tech
Sep 7, 2006 08:16 PM
