80 camaro door latch problem
Old Aug 23, 2017 | 09:07 PM
JD Z's Avatar
Default 80 camaro door latch problem
I think it is the latch. The door is level and has no wiggle...so the hinges are good and tight (bushings look good). The door takes a very strong push to get it to close latched. It closes half latched. Are there some tweaks to make? Ideas from your experience with cars of the age?
Old Aug 23, 2017 | 10:22 PM
Zspoiler's Avatar
Have you tried to adjust the striker?
Old Aug 23, 2017 | 10:28 PM
JD Z's Avatar
I have not. If it can be moved, that would likely solve the problem. I assume then if I loosen the striker it can move a little up/down/forward or back? Thanks for the idea!
Old Aug 24, 2017 | 04:46 PM
Zspoiler's Avatar
There is access through the vent .
Old Aug 24, 2017 | 09:35 PM
JD Z's Avatar
Thanks guys. Adjusting the striker worked perfectly. Door closes smooth now.
bigwave1971
Feb 6, 2017 09:23 PM
SB60
Jun 29, 2011 09:33 PM
jealousfall
Jun 2, 2009 03:51 PM
TorchRed69Rally
Oct 20, 2008 11:00 PM
frenchsquared
Feb 20, 2008 09:05 PM
