Picture of door handle at latch?
Old Jan 23, 2017 | 04:42 PM
bigwave1971's Avatar
Default Picture of door handle at latch?
Does anyone have or able to take a picture of the push button door handle on the inside of the door where it meets the door latch? I'm having a hard time figuring out how they meet up. I put the handle and latch on and it seems the push button end wants to slide on the latch lever causing the push button end not to work, its like there should be a guide of some type on the push button rod to make it stay straight. all parts are new and its been 9 months sense I had it apart and I have forgot how to old one went. Thanks
Old Feb 6, 2017 | 09:23 PM
lwh's Avatar
lwh
I had the same problem with all new door parts, including door skins. I ended up taking a bolt about 1+" long, cutting off the hex head, and drilling a hole lengthwise 3/4 the way through bolt. Made the hole the same diameter of the push pin. Slip the bolt over the pin and it effectively extended and stiffened the pin. You'll need to experiment how much to extend the push pin. I had to do this to both doors and it did the trick. The doors open like a new car. Hope this helps.
SB60
Jun 29, 2011 09:33 PM
jealousfall
Jun 2, 2009 03:51 PM
TorchRed69Rally
Oct 20, 2008 11:00 PM
frenchsquared
Feb 20, 2008 09:05 PM
MassholeLT1
Dec 1, 2007 07:16 PM
