79 Camaro Turns over KOEO
Old Jul 27, 2014 | 09:13 PM
Branley's Avatar
Default 79 Camaro Turns over KOEO
I have a 1979 Camaro I just received and it used to be a 350 car but is swapped to a 305 and it turns over and tries to start when I turn the key on not trying to start it. Any ideas?
Old Jul 28, 2014 | 07:58 AM
Yes. Look at the small starter wires hooked to the solenoid. Should be one on each terminal, and they're probably either swapped wrong, or two are both on the same side. One hooks to the alternator, so it's feeding back when you turn the key on. Swap to the other terminal and it should work.
laredocamaro
Jul 26, 2011 07:33 PM
Jerry95lt1
Mar 29, 2011 12:24 PM
Jerry95lt1
Oct 28, 2010 01:38 AM
jramirez911
Jul 19, 2010 02:20 PM
NEW_CAMARO_OWNER
Apr 28, 2010 06:34 PM
