LT1/LT4 Tech 1993-1997
95 camaro turns off
Old Oct 20, 2010 | 06:52 PM
Jerry95lt1's Avatar
Default 95 camaro turns off
Hey guys, my 95 z28 has been turning off on me. The rpm's start to go down and when i accelerate in order to avoid it, it still dies. could it be a faulty sensor? i turn it on again and it takes a few tries but when i finally get it to turn on its completely normal. please help!
Old Oct 21, 2010 | 11:29 AM
torque_is_good's Avatar
Does it light the service engine light? If so, an Actron 9145 will read your car's codes (I have a 95Z too)
Old Oct 21, 2010 | 11:57 AM
change fuel filter and check your fuel pressure. could be fuel pump is gettin tired.
Old Oct 22, 2010 | 02:48 AM
Jerry95lt1's Avatar
i changed the fuel pump a year ago so i dont think its that. i'll try changing the filter. thanks!
Old Oct 22, 2010 | 02:54 AM
Jerry95lt1's Avatar
Default maybe
you dont think it could be the mass air flow sensor?
Old Oct 22, 2010 | 06:46 AM
well yes it could be that or a host of other things. just figured check fuel pressure doesnt cost anything,,, well if you have a tester it doesnt. gert it scanned for trouble codes to.
Old Oct 22, 2010 | 09:12 AM
BasicConcepts's Avatar
Technical User
you can rent a fuel pressure gauge from autozone for like 100$ but you get it back when you bring the tool back
Old Oct 22, 2010 | 12:28 PM
Jerry95lt1's Avatar
Smile really?
i didnt know that. thanks! so i get all my money back or just some of it?
Old Oct 22, 2010 | 12:56 PM
some charge some dont. you may get away with testing in the parking lot and not have to put out anything. see if they can scan it for codes too.
Old Oct 22, 2010 | 06:55 PM
I've yet to see a parts store that can scan a 95Z. The only handheld I've found that works with the 95Z is the Actron 9145. It needs no special cable or power source. It plugs into the OBD2 connector and reads the computer.
