79 Camaro High oil pressure blow out gaskets
Old Jun 20, 2014 | 09:04 AM
Dve33's Avatar
Originally Posted by craby
do a compression test on all cylinders, as ^^^ said blown head gasket can cause the gushers. oil pressure changing like that suddenly is concerning, what was the pressure before the run.
I hve it logged somewhere, I can't find it. I don't think it was toouch different now that I'm thinking about it. It's also getting hot out so it will be a bit different.
Old Jun 20, 2014 | 09:18 AM
Whenever I go to the big box parts stores, I first look at their parts online. Then I write down the various part numbers I want to look at, and give them the list when I get there. It avoids all the what year, make, model, questions that don't always apply.
Old Jun 20, 2014 | 09:11 PM
Ok I'm gonna toss out some left field chit but... here goes. First PCV hooked up? You dont evac the crankcase pressure, it will make itself a vent. Two, deep left center here. "Top end kit" meaning heads? Try and add another gasket under the dizzy. My heads were cut after dropping a valve and I had SERIOUS psi. Like pegged at all times high. I blew oil filters off the damn thing. So I tried an Moroso race filter because they were thicker. Thats when I got the pegged readings, no other filter lasted long enough to see whats-what. This was before forums and stuff so fixing it was a ask around deal. Finally asked the guy who did the machine work what I could try. Shim the dizzy he says. Whaaa? Yup the heads being shorter shoved the dizzy into the pump and when I clamped it I preloaded the gears in the oil pump against the pump housing and there was zero pump leakage. MSD makes shims as well as a slip collar dizzy for this situation. Sure enough. The heads are one resurfacing #3 and I have a shim under the dizzy right now. The combo has had two more short blocks under them and no issues with pressure.
Old Jun 22, 2014 | 04:35 PM
jimm418's Avatar
mine has a high volume oil pump cold 60 psi warm i think 50 maybe a lil higher running it hard highest i seen was 70 so i think thats ok and mine is a 383
Old Aug 12, 2014 | 04:40 AM
Dve33's Avatar
So the guy who was "helping" me screwed my damn harmonic dampener. I was able to get a new one. Sealed it all up. No more leak. For 15 min. Where the front oil pan seal meets the timing cover there is a little drip out of the bottom. I think it was improperly seal by my "helper". Im going to clean the heck out of it with break cleaner and triple black that sucker.
Chevy101
Jun 20, 2013 11:55 PM
01ssls1
Jan 8, 2012 01:18 PM
CNCman
Aug 4, 2009 08:06 AM
Rooftopnick
May 31, 2009 04:12 PM
Saint_Ali
Jan 28, 2007 09:12 PM
