high oil pressure
Old Jan 17, 2007 | 11:29 PM
Saint_Ali's Avatar
Default high oil pressure
normally in the mornings it is fairly warm, but the last week we hit a cold front, it has been around 30-35 degrees and i have noticed a higher oil pressure while driving, does the colder weather cause the oil pressure to be higher ?
Old Jan 17, 2007 | 11:39 PM
jtvyper456's Avatar
Default RE: high oil pressure
How high is it getting? Also, does it return to normal when the engine warms up.
Old Jan 18, 2007 | 12:02 AM
Saint_Ali's Avatar
well id say sometimes its 10-15 psi higher than it normally is, maybe the pressure sender could be off, but it does return to normal after about 20-30 min of driving
Old Jan 18, 2007 | 01:16 AM
MadMikeZ28's Avatar
The oil is cold and a little heavier. What weight do you use? Does it turn over a little slower also?
Old Jan 18, 2007 | 02:03 AM
Saint_Ali's Avatar
i use 10w-30, it takes like an extra second to turn over i guess, its not that hard to start or anything
Old Jan 18, 2007 | 01:30 PM
Pretty well normal for the weight oil you are using. Pressure should drop as the engine gets warm, but if the weather is verycold it keeps the oil pan cold enough so that the oil never gets to normal temp, especially if you are using a cold stat.
Old Jan 24, 2007 | 12:58 AM
92camaroRS's Avatar
Your in good shape.
Old Jan 28, 2007 | 02:18 AM
Saint_Ali's Avatar
one reason the oil pressure changed is because i switched from k&n to fram oil filter, should i use 5w30 instead of 10w30 ?
Old Jan 28, 2007 | 09:12 PM
bluovlh8er's Avatar
i heard that fram is the worst filter and k&n, mobil 1 is the best for flow. also put in what oil weight the car calls for you cant go wrong then.
Chevy101
Jun 20, 2013 11:55 PM
ranoman420
Oct 24, 2010 06:19 PM
nnewquist
Feb 7, 2010 12:01 AM
CNCman
Aug 4, 2009 08:06 AM
93v6
Jan 10, 2008 09:00 PM
