72 runs hot on hills
Old Aug 15, 2014 | 10:17 PM
buferd's Avatar
Default 72 runs hot on hills
i have a 72 with 350 auto. temp runs 190 until going up a hill. It will reach 220. New water pump, thermostat (185) flushe rad. Fan fits inside shroud but 4 inch away from rad. I added a 16 in blowing fan on front of rad. No Help.
Any suggestions??
Old Aug 16, 2014 | 12:16 AM
Even though the radiator was flushed some of the passages could be plugged up and flushing won't help. May want to try a new radiator.
Old Aug 16, 2014 | 12:26 AM
Also make sure your ignition timing is set right, and that it's advancing fully at higher rpm's. Small blocks generally like 34-36 degrees of full advance. Having timing tape on the harmonic dampener would come in handy. The engine is under a greater load when going uphill, and not enough advance when the engine needs it can make it run hotter. Same goes for having too much advance. And, which vacuum port is the distributor advance hooked up to?
Old Aug 16, 2014 | 01:38 AM
Sudstoy's Avatar
First thing I would do is use a infared thermometer to check and see your gauge is reading correctly. The thermostat housing should be a good spot to check once it warms up and gets to the same temperature. Another thing that. Might help is take the rad cap off when its cold and start it up. I don't imagine the head gaskets are toast but if you have exhaust coming out they are gone. I'm not a mechanic but those are easy tests. Also do not assume new parts always work. Thermostats are cheap and waterpumps can be checked easy enough
Old Aug 17, 2014 | 10:21 AM
Since you've figured out the pusher fan isn't helping, I'd sure remove it, as it will only create more air flow issues blocking some air while cruising. I'd agree that checking timing, and making sure it's spot on, and the advance is working properly are critical to optimum cooling.
Seeing Stars
Jan 24, 2013 09:35 PM
19IroczCamaro87
82-92 V8 Tech
Oct 16, 2011 06:41 PM
motox-010
Oct 26, 2009 12:56 PM
Falligator
May 9, 2008 12:20 PM
sewerrat
82-92 V8 Tech
Aug 15, 2005 03:17 PM
