350 to 383
Old 05-14-2010, 06:36 PM
18436572's Avatar
it's just for the next time the engine gets tired.
most times a guy while build just one engine for his ride.
others are going to need four or five a summer!
i'm worried about what goes in your tranny ... so you should be too!!!
stock clt and plates are no match for all those ponnies. lol
if you had a 400 th it would have been closer
but a good aftermarket stage 2 or 3 tranny would be the best bet
it is possible to get what you need to build yours , but it needs to be done perfectly
really easy if you can get your hands on full kit and you have the tools to compress the piston springs, a set of small seal picks, the bushings need paticular tools usually one for removal and sometimes one for installing. did i mention the manuel for your tranny to help you if you get mixed up. a place to clean and then assemble a perfectly clean tranny.
  #32
Old 05-14-2010, 07:33 PM
A 383 is typically a .030 over 350 (4.030") witha 3.75" stroke. That gives 382.667" engine.
  #33
Old 05-14-2010, 07:42 PM
Rizzo408's Avatar
dam, my expenses just got a lot bigger. looks like im waiting a little longer to do this work to my car
  #34
Old 05-14-2010, 07:51 PM
Hey just pick away at it. I've been at it off and on for 37 yrs! Almost done now!
  #35
Old 05-14-2010, 08:10 PM
Rizzo408's Avatar
haha nice. your car looks awesome by the way. i found this webisite monster-transmissions.com. they have a remanufactured th350 thats rated up to 550 hp! and for only 1k. i might be able to pull this off!
  #36
Old 05-14-2010, 08:16 PM
DONE. never
  #37
Old 05-14-2010, 08:18 PM
I would by a Monster tranny. I almost did acually but went four speed instead.
  #38
Old 05-14-2010, 08:24 PM
Rizzo408's Avatar
i was just looking and they also have th400's stage 2 rated up to 500 hp, for 1,100. i am strongly considering changing to a 4 speed
  #39
Old 05-15-2010, 08:32 AM
18436572's Avatar
mmmm nice stuff for sure!!!
but ... keep in mind what you want as a car in the end.
if you put too much power in the thing you should plan on diff upgrades , axles , frame connectors , suspention mods , tires , wheel wells , etc ...
  #40
Old 05-15-2010, 09:07 AM
Was your second sentence in reference to the first one? The T400 is a three speed.
