2017 Camaro dont start no crank and engine light stay on
Old Jul 1, 2019 | 02:14 PM
Corvin5TH's Avatar
Default 2017 Camaro dont start no crank and engine light stay on
Hello guys im a new owner of camaro 2017. i both it second hand here IN UAE. i have a problem with my car it wont start. so i try to buy a new battery to even tho my old battery is still good.
so i change my battery and hoping it will start but the result is still the same.. i try to remove the battery for a while to maybe reset the car but end up with the same result. so i check the fuse F13 for starter and found OK. so again i try to start the card push the break and push the start button but the lights on the gauges turn off and the only lights on is the engine light and park brake. then after pushiong the start button all the lights will come back but no engine cranks. im using the car daily so its not stock for a long time. i just change the oil send it for service then the second day after the oil change it happen.what could be the possible problem? hoping someone could answer..
Old Nov 29, 2024 | 07:28 AM
Sputnick's Avatar
Did you ever figure out the cause of this? Having a similar scenario on my 17 at the moment.
aden34
May 6, 2012 04:23 PM
allen707
Sep 25, 2011 08:55 PM
NovaBrad
Jun 28, 2010 03:14 PM
89street
Oct 18, 2009 07:23 PM
ryan88z
Mar 9, 2009 09:01 PM
