2017 Camaro dont start no crank and engine light stay on
Hello guys im a new owner of camaro 2017. i both it second hand here IN UAE. i have a problem with my car it wont start. so i try to buy a new battery to even tho my old battery is still good.
so i change my battery and hoping it will start but the result is still the same.. i try to remove the battery for a while to maybe reset the car but end up with the same result. so i check the fuse F13 for starter and found OK. so again i try to start the card push the break and push the start button but the lights on the gauges turn off and the only lights on is the engine light and park brake. then after pushiong the start button all the lights will come back but no engine cranks. im using the car daily so its not stock for a long time. i just change the oil send it for service then the second day after the oil change it happen.what could be the possible problem? hoping someone could answer.. |
