10 bolt and ? gear
Old Dec 20, 2006 | 07:23 PM
skar's Avatar
Default 10 bolt and ? gear
I now have my self a 68 RS . It now has a 10 bolt with a highway gear 327motor T350 trans.
Long term new 383 motor and 700r tranny.
Short term New rear end. This is not a drag car It will be my weekend hotrod.??? what gear should I get 3.55 or 3.73
Will the 10 bolt be OK with new gears and axles (street tires only)
I think the 3.73 would be nice with the 700R but with the t-350 the 3.55 would be better?
It will be a year or so before I can get the 383 / 700r setup.
What do you think. (do not want to have to do this twice. and do not do a lot of highway driving)
Old Dec 20, 2006 | 07:34 PM
ghotachevy's Avatar
Default RE: 10 bolt and ? gear
3.42
Old Dec 20, 2006 | 10:17 PM
shnormo's Avatar
3.55 I liked my 3.73, but it was hard to get going w/o spinning the tires with stock tires and suspension
Old Dec 22, 2006 | 09:47 AM
bigbrc51's Avatar
3.73 with 700r4 the best out ther
Old Dec 24, 2006 | 04:29 PM
69camaro1's Avatar
3.73
Old Dec 25, 2006 | 03:10 PM
skar's Avatar
what size tires are you guys going with on your 1st generation
Will a built 10 bolt hold up with street tires. (no drag strip)
Old Dec 26, 2006 | 03:05 AM
GRIFF's Avatar
To convert to 700 you would need to shorten driveshaft, move trans crossmember and address the lock up torque converter, some of the 700s have a different output spline also. A friend of mine put a 700 in his 79 Z which was mostly a strip car, the drop from first to second wouldreally dropthe rpm of the engine. I had a th400 I gave him and he had rebuilt it was a huge improvement at the strip. In general the only advantage of the 700 is the overdrive. I doubt you would see a big difference between the 3.73 to the 3.55 ratios it would depend on the power curve rpm of the engine/ tire size, given its a 383 I would lean towards the 3.55:1 though.
As I think you might have already heard the 1st gen 10 bolt is regarded as a weaker rear end, the 2nd gen 8.5 10 bolt is stronger as is the 12 bolt and the ford 9 inch. Will your 10 bolt hold up for street crusing just for driving around I would say yes. If you plan on putting alot of stress on it with a high torque engine, posi and higher gears running it hard I would say you are in the danger zone. 12 bolts and the ford 9" can be expensive the 2nd gen 8.5" 10 bolt are of a different dimention the easiest way to go might be to find a late 70s (you want to check the years on this) nova/ventura 10 bolt 8.5 inch I believe they are the same dimention as yours and mightbe more worth while to sink your money into.
Old Dec 30, 2006 | 02:50 AM
rat454's Avatar
I had a 71 with a 10 bolt 3.07 0r 3.08 rear gear....factory posi with a 350 4 speed drove it for 3 years then changed to a hard shifting turbo 350. did a cam change and i drove the hell out of it for2 moreyears, had no problems.comething like 50,000 miles.built a 427, nash 5 speedand changed to a 9 inch. sold the engine/tranny and rear to a guy with a 78 and he's still using it....My suggestion is that if it ain't borke, change the fluid to synthetic and drive the hell out of it...
Greg
Old Dec 30, 2006 | 11:57 AM
skar's Avatar
GRIFF
Thanks I think I will order a 12 bolt from DTS or srange this spring. It will be a year or two before the 383 stroker and new trans.($$$) I will have to see what rpm at 60 eash gear will do on a 26.1 tire and t350 trans.
3.4putter
Jan 28, 2012 07:35 PM
Hit n Run
May 26, 2009 10:13 PM
Hit n Run
May 25, 2009 10:24 PM
gozzy341
Nov 4, 2007 08:52 PM
roscoe
Sep 8, 2007 11:09 AM
