10 bolt 8.5" ring gear
Old May 24, 2009 | 08:41 PM
Hit n Run's Avatar
Default 10 bolt 8.5" ring gear
Anyone heard of a 2.92 ratio in the 10 bolt rear end with 8.5" ring gear?
Old May 24, 2009 | 09:03 PM
SpecterGT260's Avatar
Ninja Administrator
im sure they make one, or something close to it. why do u ask?
Old May 25, 2009 | 09:09 AM
Hit n Run's Avatar
Default gm 10 bolt 2.92 rearend
I race a 1974 camaro at Antioch Speedway.The cars that are running the gm 602 crate motor,have found that the 2.92 ratio rear end works really well.We race on a 3/8 mile dirt track in 1st gear with the th350 transmission.With this rear gear the motor runs at about 5300 rpm which is where it makes peak power.I'm trying to find a set of these gears for my self.Anyone who knows where they are available please let me know.
Old May 25, 2009 | 11:34 AM
Ninja Administrator
have you checked w/ motive? yukon also makes alot of different gear types
Old May 25, 2009 | 12:19 PM
Hit n Run's Avatar
Default gm 10 bolt
I have not been able to find those gears anywhere.They supposedly were available OEM,but i'm not sure what models came with that gear.
Old May 25, 2009 | 07:15 PM
Ninja Administrator
have u considered upgrading to a 12 bolt or 9" running a 602bb will be loads of fun for ur 10 bolt, even if it IS one of the older 8.5"
Old May 26, 2009 | 10:13 PM
Hit n Run's Avatar
Default gm 1o bolt 2.92 gear
I found out on another site that a 2.93 8.5" ring gear came in the 1973-1975 Buick Regal.
paul kellam
Apr 3, 2014 03:58 AM
ittybittyfds
Feb 23, 2011 01:17 AM
1995Camaro
Aug 9, 2010 06:15 PM
Hit n Run
May 25, 2009 10:24 PM
dynarider33
Jan 3, 2009 12:53 PM
