Chrome Rally rings
Old Aug 17, 2011 | 08:33 PM
Hessy66's Avatar
Default Chrome Rally rings
Is there a trick to installing the chrome rings on rally rims? I got two to stay on. The other two spring one side off when I get the other side on. Am I missing something? Doesn't seem it should be this hard to get the rings on.
Old Aug 17, 2011 | 09:39 PM
Get the bottom side started on first, but not on all the way. Then sit on the ground with your feet against the bottom of the ring and smack the top side on, then work your way all around the ring.
Old Aug 18, 2011 | 04:50 PM
Hessy66's Avatar
It worked. Apparently you have to beat them with a rubber mallet like you don't care if they get hurt. Then the popped right on.
Thanks
Old Aug 18, 2011 | 05:04 PM
You're welcome. Are the rings new, because the first time is always the tightest.
Old Aug 18, 2011 | 06:50 PM
Hessy66's Avatar
No, the rings are old/used. Just couldn't believe I had to wack them that hard to get them to seat.
Old Aug 18, 2011 | 09:23 PM
At least you should feel confident they shouldn't zing off on you if you hit a hard bump.
mach2mack
May 13, 2012 09:47 AM
kyphur
Apr 13, 2010 10:30 AM
350rs
Aug 10, 2008 02:12 AM
microkid
Dec 6, 2007 04:26 PM
Andross
Nov 13, 2006 09:55 PM
