head scratcher needs help
Old May 8, 2010 | 10:12 AM
HUBS67RS's Avatar
Default head scratcher needs help
I have a problem with my car shutting off ('67RS) the problem is intermitant, and occurs when braking for a turn. The motor will shut off as if you killed the ignition just about the time I have come to a stop prior to turning. The motor will start right up again no questions asked. I have noticed it has not happened yet when i have not used the turn signal to turn. But - it does not happen everytime i do use the turn signal. I believe the car has been converted to a 4-spd on flr from 3spd on column, but has the original column & wheel. It also has a fairly fresh dual point distributor & MSD ignition which seems to be running well. I really think it is an electrical/ignition problem but not sure where to begin. anybody have any advice or experience with this issue.
Old May 8, 2010 | 10:28 AM
sure sounds like your on the right track. unfortunatly it looks like your gona have to tear into the column. could also run a new wire from the ignition to the coil but thats kinda funky. good for the short term.
Old May 8, 2010 | 10:31 AM
18436572's Avatar
check your ignition switch and key barrel for movement.
try a gentle wiggle test with the car running if you don't find anything physicaly lose or corroded connections.
for sure it is electrical.
Old May 9, 2010 | 01:05 AM
The turn signal could be a coincidence, especially since you say it's not consistent. I would check the float level in the carburetor.
If the level is set too low, slamming around a turn could momentarily starve the engine.
Old May 10, 2010 | 08:23 AM
HUBS67RS's Avatar
hadn't thought of that - will check it out. My hunch is still electiric. thanks
camaro_383
Nov 26, 2013 07:50 AM
NapolitanoZ28
May 31, 2011 05:29 PM
1989_RALLYSPORT
Mar 8, 2011 06:48 PM
noer
LS Series Tech
Sep 12, 2010 10:15 PM
Tyler40
Jun 15, 2010 01:58 PM
