Over my head?
Old Nov 25, 2013 | 02:24 PM
camaro_383's Avatar
Default Over my head?
So I just picked up a "1984" Chevy Camaro with a 383 (stroked) carbureted, automatic, original paint, original interior and the damn thing leaks like crazy. I was wondering if there was any advice.... well in general. Ways to drive to extend engine life, mods for the future, small tweaks that will help it perform better. Anything at all will be very appreciated! Thanks in advance.
Old Nov 25, 2013 | 08:39 PM
YAV8's Avatar
When you say leaks, you mean oil, water, antifreeze, gear lube ect?
Old Nov 25, 2013 | 11:52 PM
camaro_383's Avatar
So far coolant and antifreeze is coming out the bottom. I seem to have found some oil has gone missing but there's no indication underneath the car.... So I'm kinda at a loss for where exactly it went. I'm having a guy look at it tomorrow so I can get a clear picture of what I'm up against.
Old Nov 26, 2013 | 02:44 AM
TipTricky's Avatar
Hate to be the one to say it but it may be burning the oil if the rings are bad or if the valve seals are bad. Does it smoke alot?
Old Nov 26, 2013 | 02:58 AM
jjz28's Avatar
may be going in the coolant too. that may be where the coolant is going if you have a bad headgasket. If it was a newer build, the headgasket may have needed torqued again.
Old Nov 26, 2013 | 07:50 AM
YAV8's Avatar
With antifreeze coming out the bottom you may have a loose radiator hose or a leaky radiator. Not a hard fix as for the oil more details are needed.
noer
LS Series Tech
Sep 12, 2010 10:15 PM
z28rob18
Sep 2, 2008 05:50 PM
00camaross
LS Series Tech
Feb 20, 2007 10:53 PM
Saint_Ali
Oct 23, 2006 01:08 PM
dzroc
Jun 13, 2006 10:42 PM
