fuel gauge troubles
Old 06-01-2011, 08:09 PM
southw2's Avatar
thanks thats the way my is grounded also
Old 06-12-2011, 10:07 AM
southw2's Avatar
I just purchased a new autometer colbalt c2 fuel gauge to go into my new console with the 4 gauge 2 1/16 " mounting. I will wire it dierctly to fuel sender and discounect the one in the dash and leave it in place unti i find a tic toc to replace the original fuel gauge. I do belive i either have a intermitting bad ground or sender wire problem because it works intermittingly.
Old 06-25-2011, 04:25 PM
southw2's Avatar
thanks for all the help with my fuel gauge guys. I decided to install a floor console with 4 2 1/16 autometer gauge pod c2 cobolts. included a full sweep fuel gauge.
Old 08-11-2011, 12:16 AM
tk421's Avatar
Its been a few months since the last post in this thread, but I just had the same thing happen to my gas gauge tonight. Its at a 3 o'clock position with the key on, however when the key is turned off the needle does go back down like it wants to function. The needle ranges from between 2 and 3 o'clock.
Old 02-04-2012, 02:59 PM
oldsmerc's Avatar
I have the same 3:00 issue with my guage. I bought a new one and it came packaged at 3:00. I have run a direct ground to the cluster and both guages stay at 3:00, power on or off.
Old 03-05-2012, 07:22 AM
southw2's Avatar
When i lower my fuel tank i found the ground wire coming from the sending unit just barely hanging on. That was my problem , just replaced the whole sending unit after 44 years it was time !!!!
Old 03-06-2012, 01:56 PM
mardaman1's Avatar
I have a 94 camaro z28 and everytime I stop my gas meter well the stick (gauge) goes down than once I step on the gas it goes back up what can be the possible problem
Old 03-10-2012, 06:14 PM
keelie06's Avatar
i have a 93 camaro and was checking out why my gas gauge will not work it shows over full under the car i have found a black wire with a white line down it and cant find out where it goes any ideas the wire comes directly from the gas tank
Old 05-26-2017, 01:00 PM
Gunny's Avatar
Default Great information and knowledge
Hello every one. I just joined this site. I just want to say, Wow! All the great information on here is wonderful. A lot of my issues with my '67 Camaro SS have been covered, and I felt great with other issues that I worked out my self have also been covered. So thank you for your kind and thoughtful messages I have read. I wish I could have found this site last week as I was working on throttle issues. I'm going to dig in and start working on all the awesome info I learned yesterday, so thank you gentlemen. If I can help, I will. Take care
94Zman
05-30-2013 06:54 PM
keelie06
09-27-2012 12:18 PM
greyscot35
03-01-2008 07:10 PM
vzfox
11-10-2007 10:05 PM
BlueKitsune
10-05-2007 07:54 PM
Quick Reply: fuel gauge troubles
