1967 SS 350 w/AC Cooling Fan Question
Question - I have a 1967 SS350 original engine numbers matching - the cooling fan is not OEM and we want to bring it back to OEM. What are the parts required for a stock 350 SS camaro - the fan and fan clutch, what are they exactly?
Classicindustries doesn't have a solid answer for me when I spoke to them. Does the 67 350 have a five or seven blade fan? Will a seven blade fan work on a 67' 350 or is the water pump length an issue? Also - will a 5 blade fan work with a clutch.
CRG is a great site and has a ton of great info.
This is what you're looking for.
CRG Research Report - 1967-69 Cooling Systems
