broken rod!
Old Jun 14, 2010 | 08:20 PM
Feed_my_stroker's Avatar
Lightbulb broken rod!
my piston rod on my 350 cracked should i get it welded or just buy a new one?
one of my pistons also got messed up i think ima buy evrything new? whats should i do?
Old Jun 14, 2010 | 09:01 PM
Replace the rod, never weld.
Replace the piston.
Do that only after inspecting the block to make sure no damage was done to the cylinder wall, crank, and the block itself.
Old Aug 1, 2010 | 06:28 PM
bwcamaro68's Avatar
I agree with Camaro 69 also
if you are looking for a replacement, contact a machine shop that you trust. They have Rods as well as pistons. if your wanting to keep it non-after market. You say it is "Cracked", were you working on the motor and found this crack as you inspected the motor?
Do you have pictures of your cracked rod or piston?
Old Sep 19, 2010 | 04:13 PM
67YenkoJC's Avatar
Save up a few hundred bucks and get a 383 stroker kit! since you are going to tear it down anyway, why not?! Kit comes with new crank, rods, and pistons.
Kubs
Jan 4, 2012 11:05 AM
th3po1son
Aug 7, 2008 08:33 PM
peter
Nov 6, 2007 11:41 AM
littlefooler
67-69 V8 Tech
Oct 7, 2007 10:37 PM
