Battery Cables
Old Jul 27, 2022 | 11:02 AM
Eric Sabatier's Avatar
Default Battery Cables
Hello
I need to order a set of battery cable for my 68.
Car had an Air Conditioning but this do not work, no compressor in place, ...
What is the difference between the A/C and non A/C cables?
Which ones should I need.
Then RockAuto lists a battery to ground cable and a battery to switch. I assume I need one of each. Battery to switch actually goes to the starter, right?
They also list "top mount cables". What are they?
Old Jul 27, 2022 | 05:56 PM
Top mount would be for std. battery posts VS the GM side mount bolt on cables.
Can't help with AC VS non AC,maybe the AC are longer to get around the compressor? Just a guess on my part.
If your car had AC I would just order those for a sure fitment.
Old Jul 28, 2022 | 03:36 AM
I never heard of side mount battery cable. Seems surprising as out of 13 cables Rock Auto has only 2 "top mount" cables. Does everybody use sde mount cables.
From the pictures their "not noted as top mount, so should be side mount" cables looks like standard to me (ie top mount)
I am a bit lost...
https://www.rockauto.com/en/catalog/...ery+cable,2500
Old Jul 28, 2022 | 05:45 AM
I am a bit lost...
Stock GM cables bolt onto the side of the battery going back to the early 1970's I believe,not sure what year it started.
Linda
Jan 31, 2022 10:50 PM
Terry
Jan 21, 2018 12:27 AM
iLL95
Nov 8, 2011 04:04 PM
Fterr99ss
LS Series Tech
May 1, 2011 08:18 PM
6v49der
Oct 15, 2007 01:16 PM
