350 performance options
Old Apr 25, 2014 | 02:53 PM
camaroteen82's Avatar
then they don't have stock valves because when I measured the valves they were 2.02 and 1.94. so would these bigger valves help the heads flow better?
Old Apr 25, 2014 | 04:02 PM
Yep. If you're on a shoestring budget, those heads will definitely be better than the ones that are on the engine now.
Old Apr 25, 2014 | 04:24 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
Camel hump heads were the thing to have......back in the day. Performance wise, they're boat anchors now compared to the Vortec or aftermarket heads. The only real reason to pay money for camel humps is if you're putting together a vintage numbers correct engine.
Or you have an grandfather that will never look at other head other than camel hump even when he had a motor with AFR aluminum heads on it. Lol
Old Apr 25, 2014 | 04:45 PM
Yeah, because the Camel Hump heads were the bees-knees, whippersnapper!
What's with all this modern advanced technology mumbo jumbo I keep hearing about anyway?? lol
Old Apr 25, 2014 | 10:28 PM
so that settles the top end but I still need to know a decent cam for the engine. I know dad is gonna want some decent mpgs but I know he also would like to get those back tires to chirp when he wants. is there a cam that can do the job?
Old Apr 25, 2014 | 11:42 PM
June 2010 ROTM
I have a Comp 280 grind in my 350 that's in my 33 ford pickup. sounds good and the motor runs hard, but I have a little bit more work in the rest of the engine.
had a comp 286H in a 400 small block that was a good cam.
you could run a stock cam and get the tires to chirp
Old Apr 26, 2014 | 09:38 AM
where would I find a stock l-48 cam?
Old Apr 26, 2014 | 12:19 PM
June 2010 ROTM
crane cams has a master list of all the factory grind cams. have to watch though since some are factory solid lifters.
http://www.cranecams.com/uploads/catalog/pp0811a.pdf
Old Sep 12, 2014 | 10:34 AM
92z5speed383's Avatar
for the price of the alum heads you can get a lot more power we have some for sale here at the shop I can make you a deal on email me at Daniel at white performance dot net
strikeone
Jun 19, 2008 08:29 AM
djsevilways
May 17, 2008 12:42 AM
MarineMurphy
Sep 16, 2007 02:20 PM
