Transmission leak at pan
Old Jun 18, 2013 | 06:10 AM
tuckaaron's Avatar
Default Transmission leak at pan
My 67 camaro (350/TH350) had a bad leak over the winter. I found and replaced a rear seal. During this I found that one side of the transmission crossmember bolt was missing the nuts, the other side was good.
I am assuming that the transmission pan was leaking the whole time as well. I replaced filter gasket and bolted back up. I overtightened and stripped a bolt. I have already drilled and replaced the bolt.
So there is still a leak in the pan and I am wondering two things....
1. Could I have used bolts that were not correct, which is why it tore off so easy, and I need to replace them tighter?
2. Could it have warped from the crossmember loose on one side?
Thanks
Old Jun 18, 2013 | 10:54 AM
1. Not if the bolts are tight against the pan.
2. You're suggesting the transmission case warped? No.
Did you check to make sure you don't have a leak at the speedo gear housing? That's a VERY common leak prone spot, especially the more the car sits idle. You could have a leak there, and it would run down and along the pan ledge, making it appear the pan is leaking.
Old Jun 20, 2013 | 06:09 AM
tuckaaron's Avatar
Thanks, I took a quick look under at the speedo. I realized I also changed out the ring in it last year but low and behold you were correct.
Thanks
Old Jun 20, 2013 | 11:33 AM
Been there, had that. The aluminum speedo gear housings are notorious for causing leaks. Mine used to burp out a lot of fluid when sitting over the winter, even after replacing the o-rings like you did. What does take care of the problem like a charm is a replacement steel housing like this: Speedo Gear Housing. Mine hasn't leaked since.
grasshopper645
Sep 2, 2013 10:13 AM
98camarov6
Sep 20, 2012 12:58 PM
pcarollo
Jun 13, 2012 11:08 PM
hdrocks
Feb 6, 2012 12:40 PM
blacksunshineSS
Mar 30, 2006 10:20 PM
