Kick-Down Trouble
Old Oct 1, 2020 | 02:23 PM
Everett#2390's Avatar
Here you go:
It may need adjusting in making it work.
First, engine off, manually pull forward of cable to the end and hope you feel some resistance the last 1/4 inch of travel.
Ensure the cable end is installed on the ball stud on bottom of carb arm.
Have an assistant floor the gas pedal and hold.
Check primary throttle ensuring they do open to max, if not, adjust linkage.
Ensure throttle does return to idle after adjustment; if not, fix it.
Hold throttle to floor, at cable bracket, pull out the clip holding the case.
Once clip is out, and with throttle floored, pull back on cable casing removing slack and install clip.
Ensure all slack is gone from cable by pulling cable forward ensuring there is no slack.
If slack is still there, pull back on cable casing with clip ou.
Remove slack, install clip, ensure throttle goes back to idle several times.
Replace air cleaner nd go for a drive.
Old Oct 4, 2020 | 01:04 PM
Eric Sabatier's Avatar
Thank you
I will check for that a bit later...
gfrench
Mar 28, 2011 08:05 PM
Hogwash
82-92 V8 Tech
Feb 13, 2009 12:53 PM
thebandit110
Sep 13, 2007 12:25 AM
redhotz28
Jul 19, 2006 11:24 PM
02renegade
May 3, 2006 01:12 AM
