Kick-Down Trouble
Old Jun 14, 2020 | 11:23 PM
f1rob's Avatar
Default Kick-Down Trouble
Folks:
Recently purchased a 1969 Camaro with a 350-300hp, backed by a turbo 350. The previous owner said the tranny was rebuilt about 5 years ago(5kmiles), and had a shift kit installed.
The problem is that the kick-down does not work, regardless of how fast, what gear it's in, or how far the throttle is depressed, the tranny doesn't kick down.
The kick-down cable is connected to the throttle o the carb, and connected to the tranny, but I don't know where to begin in troubleshooting this.
Is it an external adjustment, or something bigger? Any suggestions on where to start looking?
Thanks in advance,
Rob
Old Jun 15, 2020 | 09:11 AM
Zspoiler's Avatar
It could need to be gone through again.You dont now what the quality of the rebuild and just how it was driven in the meantime,
Old Jun 15, 2020 | 07:30 PM
f1rob's Avatar
Hi Zspoiler: you have a good point!
After I posted, I saw a similar question was posted, and a detailed reply to that one from Everett2390. If I get some time this weekend, I'll try to male the adjustment and see if that makes a difference.
Won't cost me anything, before I decide to pull the trans.....
Cheers,
Rob
Old Jun 16, 2020 | 12:34 PM
Everett#2390's Avatar
Good you found the instructions I wrote. First item I would check is disconnect the kickdown cable from carb linkage and manually pull cable forward while holding the casing, or leave casing in its bracket, and 'feel' any resistance in the last 1/4 inch of pull.
If resistance is felt, adjust IAW instructions I wrote.
If no resistance, then you might have to drop pan in seeing if cable is connected at valve body and linkage itself moves the valve.
If all goes well, then WOT upshifts should happen if governor is working.
Old Jun 16, 2020 | 11:58 PM
f1rob's Avatar
Hi Everett#2390:
I checked, and the adjustment was off. When I disconnected the cable.from the throttle linkage of the carb, I could feel resistance at the last 1/4" of travel. At WOT, the ball-stud on the throttle linkage would not pull the cable that last 1/4". I made the adjustment, however, couldn't take it for a drive tonight.
I'll report back when I get it out in the next couple of days.
Cheers,
Rob
Old Aug 5, 2020 | 11:33 PM
f1rob's Avatar
Originally Posted by f1rob
Hi Everett#2390:
Cheers,
Rob
Sorry for the delayed reply!
As mentioned in the last post, I adjusted the cable as described by Everett#2390 above, but when I took it for a ride, no joy. Kick-down was still not working.
What is the suggestion now?
Rob
Old Aug 6, 2020 | 11:17 AM
Just a FYI many shift kits crank up the line pressure to the point where the kick down will not work. They assume if you are building a high performance car you will shift it yourself. The next step is a full manual valve body. I
f this a weaker shift kit then your detente valve could be stuck. This can be unstuck without pulling the trans but may be worth it to take it to a trans guy since I assume you do not have the shift kit instruction.
And yes I know this is controlled by governor pressure but line pressure is the base for governor pressure.
Old Sep 30, 2020 | 09:22 AM
Eric Sabatier's Avatar
Hi there
could someone give the link for the post where the adjustment procedure is detailed?
Old Sep 30, 2020 | 03:33 PM
Old Oct 1, 2020 | 04:59 AM
Thank you but this link seems not to be working for me...
