69 manual trans speedo cable
Old Jun 24, 2014 | 09:37 PM
Craig Ferguson's Avatar
Default 69 manual trans speedo cable
I have a 69 with a manual trans and the speedo cable stopped working so I ordered a new one from an aftermarket supplier only to find out that the end that goes to the speedo does not fit, it seems that the square end will not fit into the case of the speedometer. It is the original speedometer so this really is strange. Can anyone tell me if their are different sizes of cables?
Thanks
Old Jun 26, 2014 | 11:50 AM
flat tire's Avatar
not to my knowledge
Old Jun 26, 2014 | 03:54 PM
The size would be different if you got a poorly made cable. All the 69 speedometers hooked up the same. Side by side, how does the new cable compare to the old one?
Old Jun 26, 2014 | 07:10 PM
flat tire's Avatar
Full Size Chevy Speedometer Cable Assembly, 1958-1968
1958-68 Speedometer Cable Assembly
Part #: 519072
Price: $21.99 ea.
Low Price Guarantee
Availability: In Stock
Fitment: 1958 thru 1968
See applications below for exact details.
Select a vehicle above or use application chart below to ensure this part fits your vehicle.
Add Items to CartQty:
.tabber{display:none;} DESCRIPTION
This Chevrolet replacement speedometer cable assembly has been manufactured to meet or exceed factory specifications and performance. You will find the fit, finish and function will work perfectly for your Chevy. You will also be pleased to know that Eckler's has sourced this speedometer cable assembly among other possible parts as the best choice for your repair or restoration project.
Old Jun 26, 2014 | 07:31 PM
Other than that one ^ being for a full size Chevy (Impala, Bel Air, etc), and 1968-older, that's just what he's looking for!
Old Jun 27, 2014 | 06:03 AM
flat tire's Avatar
my point was to show that for 10 years they all fit . not that it was the right cable
mikes68
Apr 27, 2014 01:12 PM
Heathcamaro
Jul 8, 2011 11:04 PM
cbuss54
Oct 9, 2009 09:45 PM
David56
Nov 11, 2008 11:10 PM
HOTROD MOMMA
Apr 4, 2008 09:19 AM
