Shock replacement for air shocks
Old Dec 9, 2018 | 12:22 PM
cblackmon's Avatar
Default Shock replacement for air shocks
I currently have air shocks on a 68 Camaro that were installed at some point to accommodate larger rear tires. When I got the car I replaced the old mono leafs with 2” over Detroit leafs. I would like to get rid of the air shocks now that I don’t have a clearance issue. I think gas shocks would improve the handling and ride over the air shocks (am I right about that?). My concern is the length of the new gas shock.... if I am 2” over stock in ride height can I still use a shock that is recommended for my car, or will it extend it too much and damage it over time? Thank you in advance for your help!
Old Dec 9, 2018 | 02:13 PM
Al Loyrat's Avatar
Old Dec 9, 2018 | 03:35 PM
cblackmon's Avatar
Thanks.... the bottom of my shock would not work with these, I don’t think. I am also throwing a huge amount of torque at the rear end. That being said, I will give summit a ring tomorrow. I appreciate the reply!
Old Dec 9, 2018 | 07:53 PM
Al Loyrat's Avatar
Your right, they would not work on the bottom of your shocks. That's because they're for the top of your shocks.
Old Dec 10, 2018 | 04:51 PM
Zspoiler's Avatar
I would look at a good gas shock like Manroe ,KYB,Koni ,Carrea ,Just depends on exactly on what you to to do with the car ,And your pocket book.
Old Dec 11, 2018 | 09:50 AM
cblackmon's Avatar
Ha! Touché, Al��
sgreg831
May 16, 2017 04:26 PM
81 old blue
Jan 26, 2011 06:40 PM
chase0990
Jul 23, 2010 11:39 PM
tlc69camaro
May 18, 2010 04:43 PM
TomBigBlock
Mar 22, 2010 08:38 AM
