which coil over shocks?
Old May 13, 2017 | 08:48 AM
sgreg831's Avatar
Default which coil over shocks?
I am replacing the air shocks in the rear of my 69 Camaro. They leak. Should I replace all 4? Can I just do the rears? Which brands are best? Thanks in advance.
Old May 13, 2017 | 08:49 PM
arocars's Avatar
Are you sure the shocks are leaking and not just the plastic lines. Plastic lines are very inexpensive compared to new shocks. ... Yes, you can just replace the rears. ... Gabriel Hijackers will work.
Old May 16, 2017 | 04:26 PM
57Vette's Avatar
Air Shocks were really designed to prop up a sagging rear when the car is overloaded... I think driving with the shocks inflated gives you sub-par handling and ride. Think about it... your'e propping the car up on the piston integrity and the 3/8" steel shaft. Does that sound remotely good? Get a decent pair of shocks and enjoy the ride and handling improvement.
Sudstoy
May 2, 2013 05:54 AM
Apotheosis
Feb 17, 2012 03:55 AM
Fredl
Jul 8, 2011 07:41 AM
PrinceCharmmin
General Racing/Tech
Nov 23, 2005 05:50 PM
PrinceCharmmin
Nov 23, 2005 02:03 AM
