which bolts at rear shocks
Old Jul 6, 2011 | 03:24 PM
Fredl's Avatar
Default which bolts at rear shocks
Hi
i got 2" extensions for the rear shocks and now i am looking for longer bolts.
Does anyone know which bolts i need? (regarding to the thread - is this the correct word for it) :-/
Thanks
Old Jul 6, 2011 | 03:25 PM
Fredl's Avatar
I forgot... It is for a 79 camaro
Old Jul 7, 2011 | 08:31 AM
Top or bottom extensions? I made my extensions for the bottom pin from 3/8" concrete anchors. Just took my portaband and chopped off the non-threaded end, then put a coupler nut on the shock with a locknut, and they worked fine.
If it's the top, then I believe they are 5/16", but can't remember if it's fine or coarse. I use grade 8 bolts for shock mounting myself.
Old Jul 8, 2011 | 01:10 AM
Fredl's Avatar
thanks for answer.
these are top extensions, self made.
I got also the information that the bolts could be 5/16"x18 or 3/8"x16.
My problem is, that the existing bolts are 3 different bolts, so i need to know which is original. perhabs I can rescue the inner thread of the shock mounting.
Old Jul 8, 2011 | 07:41 AM
The nuts at the top are captured nuts, and could be replaced from inside the trunk if you're good at fabrication. Or they could be removed and regular nuts used, but then it would take two people to mount the shocks, so if you have a helper that would work.
jkeaton
Apr 9, 2013 08:00 PM
jnahendo
Apr 16, 2011 09:36 AM
moparguy
Nov 25, 2008 03:41 PM
jenz
67-69 V8 Tech
Jul 15, 2008 03:23 AM
mcnair
Jul 10, 2007 10:10 AM
