rear shocks on 94 z-28
Old Apr 23, 2007 | 09:43 PM
mcnair's Avatar
Default rear shocks on 94 z-28
I just found a broken shock on my 94 z28 and was wondering how much of the interior I have to remove to get to the top mount?
Old Apr 25, 2007 | 03:44 PM
1969 SS's Avatar
Default RE: rear shocks on 94 z-28
I believe you will just have to remove the plastic covering in the rear side hatch area.
Old Apr 25, 2007 | 09:12 PM
libertyforall1776's Avatar
You have to take off the quarter panel interior plastic which involves about three screws plus the clothes hanger plastic hook, and peeling back the carpet with the back seat down to reveal the shock mount. MAKE SURE YOU SUPPORT THE AXLE WITH A JACK WHILE YOUR CAR IS ON JACK STANDS SO YOU DON'T RISK THE SPRING COMING OUT AND DAMAGING YOU AND YOUR CAR!!!
I just did this work on my '95... I would also get a MAPP Gas torch and a >= 500 ft. lb. torque air impact wrench to use with a >=3 HP air compressor for tough bolts below...
Old May 2, 2007 | 09:13 PM
zachyfarms's Avatar
since the topic is up does your car sound like you hit a pot hole when you go over normal bumps.. mine does maybe it is blown shocks
Old May 3, 2007 | 12:37 AM
jbe123's Avatar
Yea my car does that to...my 95' firebird (virtually same car as camaro). If i turn onto a driveway or go over a small bump it sounds like i bottom out but only on the right rear
Old Jun 26, 2007 | 05:14 AM
Nike Z28's Avatar
I only had to lift the carpet, nothing more!!
Old Jul 9, 2007 | 10:38 PM
deltav's Avatar
Mine did, but stopped when I changed all four shocks/struts.
Old Jul 10, 2007 | 10:10 AM
bluovlh8er's Avatar
i thought it was an easy task. to change out the rear spring and all....
jkeaton
Apr 9, 2013 08:00 PM
moparguy
Nov 25, 2008 03:41 PM
jenz
67-69 V8 Tech
Jul 15, 2008 03:23 AM
mikebrow74
Apr 22, 2008 11:30 PM
sewerrat
Aug 3, 2006 01:07 PM
