My rebuild
Old Aug 21, 2011 | 04:56 PM
  #101
ToddB's Avatar
I just got my transmission back. I sent it out last week to get checked over. The guy didn’t find anything broken just some worn out parts.
He replaced them and put all new bushings, seals and gaskets in. He also installed a shift kit. Before and after shots
Size:  52.2 KBName:  TransmissionAfter.jpg
I found all these little Teflon pieces in the oil pan. The Teflon is probably from the original timing gear.
The timing gear was replaced but I don’t think they dropped the oil pan to clean out the debris which is probably why I found this bent push rod
Size:  60.0 KBName:  BentRodinthemotor.jpg
I finished taking the motor apart. It’s in pretty good shape. I’ll send the block out next week to get cleaned then off to the rebuilder.
I still have sandblasting to do, hopefully next weekend then I can get back on the body
Size:  65.9 KBName:  CrankandCam.jpg
Old Aug 21, 2011 | 04:58 PM
  #102
ToddB's Avatar
Originally Posted by fwbsupermoto
You are making great progress. It almost kills me to see how much I have to do to even get it to move on its own. Keep up the good work and please keep on me about mine. I get sidetracked easi.....
Thanks. Take your time. It'll all come together
Old Aug 22, 2011 | 11:36 AM
  #103
psy4s's Avatar
Default Bent pushrod
What did the valve guides look like? Are you reusing the old heads?
I keep telling people the worst part of my build was the things like this you did not expect. Like every step deeper you go the more you find. Mind is comming back together, but it is like stacking the layers back on the onion after you take out the spoiled center.
It looks like you are making good progress. Keep your post going.
You will win in the end!!!!
Old Aug 22, 2011 | 11:42 AM
  #104
Looks like you're re-doing everything, including the kitchen sink!
Old Aug 22, 2011 | 04:38 PM
  #105
ToddB's Avatar
Thanks PSY4S. The guides looked ok. I will probably get the heads redone. Ill need new valves anyway cause of the unleaded fuel. I noticed 2 cylinders with mild scratches. I hope I don’t have to get the block bored out.
Did you modernize the engine at all in yours? I’m thinking about Holley EFI and MSD Ignition
Old Aug 22, 2011 | 04:41 PM
  #106
ToddB's Avatar
I have not started on the interior yet either :-)
Old Aug 28, 2011 | 05:07 PM
  #107
ToddB's Avatar
Repaired all four sub frame body mounts, before and after
Size:  52.3 KBName:  TwoAfter.jpg
Size:  45.1 KBName:  OneAfter.jpg
Size:  44.0 KBName:  ThreeAfter.jpg
Size:  46.2 KBName:  FourAfter.jpg
I have the whole frame seam welded now. Fixed a bunch of cracks. Just needs some more grinding then powder coat
Old Sep 10, 2011 | 07:07 PM
  #108
ToddB's Avatar
Default Broken Spring
Some more unexpected items from the tear down. Broken spring and bent control arm
Size:  34.4 KBName:  BentLowerControlArm.jpg
Old Oct 1, 2011 | 07:05 PM
  #109
ToddB's Avatar
I got my new Sandblasting cabinet put together. More parts to this thing than my car
Some before sandblasting
Size:  45.6 KBName:  Partsbefore.jpg
Some after sandblasting
Here is my frame back from the powder coating. It turned out fantastic. It's all seam welded and the mounts are all fixed
Size:  40.9 KBName:  FramePowdercoat1.jpg
Old Oct 1, 2011 | 11:02 PM
  #110
orocker's Avatar
December 2011 ROTM
Santas Little Helper
Wowzerz........very nice work!
